Results 1 to 10 of 12
05-18-2016, 07:54 AM #2
You should start with the effector in the middle of the bed and half way up the towers. Give it a M119. You should see nothing triggered. You should be able to manually press a tower's switch and give it a M119. You should see that tower say triggered. Until you can get that to happen, don't tell it to home.
You likely need to change the switch settings to make that happen.
