Results 1 to 10 of 12
03-14-2014, 01:14 PM #1
- Mar 2014
- 6
Would there be any way you could add in a couple of supports that connect the feet and legs to the body. The feet get to the point where the print starts each time in the same place so there is one spot that is slightly higher. As it builds up, the print head starts hitting that high spot when it moves to it and breaks the feet off the base. It is much stronger than it was before but I think it is going to need some kind of support for it to print correctly. I was thinking maybe right at the base of the feet and halfway up the leg. Let me know if that's possible. Thanks a bunch!
Here is a picture as the foot gets higher, it starts to curl up and that is where the print head starts each layer. Dog Picture.jpg
03-14-2014, 02:06 PM #2
I just read over your post again and you saw at the end you are getting curling. I missed that earlier but did suspect it. How are you sticking your print to the bed?
Bambu P1S/AMS
