Thread: need help with PLA cube
05-03-2016, 11:57 AM #1
- May 2016
result.jpg?? 3-5-2016 23 39 52.jpg?? 3-5-2016 23 40 33.jpg?? 3-5-2016 23 41 00.jpg
I have made the 20mm cube, and the bottom is 20mm, other dimensions are not. Besides mading this cube, I have made a cuboid also having the same problems. Can you suggest what's wrong with my print ?
temperature: 205 heatbed : 60 autobed enabled with a proximity sensor
05-03-2016, 02:34 PM #2
- Apr 2016
- 120
Extrusion rate is probably a little high. Take it down a couple of % and see if the dimensional accuracy improves.
Looking at the pictures you have a few other issues with print accuracy as well. Worth checking belts etc. are tight and probably slowing things down a bit as well.
