10-04-2016, 12:34 AM #1
- Oct 2016
Good troubleshooting. Thanks!
I will add the solution to my machine's "def" error...
Check the wiring in the thermistor terminal connectors at the motherboard, both wires should be on pins 1 and 3 (outer pins). Pin 2 (middle pin) should be vacant, at least on mine.... check the voltage between pins, correct set should read about 5V off the motherboard.
