Results 1 to 10 of 14
08-06-2016, 09:39 AM #1
- Aug 2015
- 10
FYI the latest Simplify3d update (June 2016 ver 3.1.0) includes a profile for the Qidi Tech 1 in it's printer model choices. I haven't compared all the settings to the ones listed in this thread, but it seems to work well for me.
09-04-2016, 09:59 PM #2Editor in Chief
Bitsonline
01-22-2017, 09:27 PM #3
- Jan 2017
I know this is not the exact printer but I am looking for this same information for the QIDI X-ONE to be used in Cura. Any help would be appreciated - trying to get a head start on the setup just ordered this printer today from Amazon.
01-24-2017, 07:37 PM #4
- Jan 2017
Hello all- new here to the forum and just bought a QIDI X-One. I'm looking for some direction here please. So I hate the stock software that the X1 came with and want to use Cura (2.3.1) which I am accustomed to. I'm looking to get the proper info set up in Cura for the best prints. I can't seem to find any post pertaining to this printer. I know Simplify 3D supports this printer but really did not want to spend 150$ on software. Any help would be appreciated....
John
01-24-2017, 07:38 PM #5
- Jan 2017
Or if anyone have Simplify 3D I would love to see the setting it has for this printer so I can use Cura which I as used to... Thanks you all.
12-22-2018, 08:02 PM #6
- Feb 2016
- 96
Hi, I am using a QIDI Tech Dual. Recently, I started noticing this weird issue that has stopped me from being able to print anything. I slice in Simplify3D and upload the gcode to Octoprint. The first thing my printer is supposed to do is move the build plate to the top and the head to the start position. For no reason, the head has started moving painfully slowly, to the point where I have to cancel the job because I don't want to wait for it. I have tried different models and even upgraded to the latest build of Simplfy3D. This happened in the last version as well. I have tried jogging the build plate and the head in X, Y, and there are no issues with speeds at all. The belt isn't broken as far as I can tell and the steppers work fine in jog position.
Can anyone see any issues? I have not touched my configuration for years and it's always worked. Thank you.
Code:; **** Replicator 2X start.gcode ****M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T1 ; Load left extruder offsets G1 X-110 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T1 ; Stabilize left extruder temperature G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-65 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-65 F180 ; Wait for ooze G1 X110 Y-65 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
