Thread: layers adhesion
04-04-2016, 04:47 PM #1
layers adhesion
so ive been upgraded my slicer to S3D..
the prints are a lot cleaner...and the overall look it beter...
but ive goten that :
and if you cant see in my 4K picture
the first layers got poor adhesion...broke apart very easy
like i said...the prints do look cleaner somehow
but the overall strength/sturdiness is weaker
any Suggestions??
cheers.!
04-04-2016, 11:37 PM #2Hex3D - 3D Printing and Design http://www.hex3d.com
04-05-2016, 05:32 AM #3
Increase your print temperature.
That usually solves most layer adhesion issues. 5-10c extra can make a lot of difference.
I find that the conventional advice is to try and print at as low a temperature as you can.
I tend to do the opposite and print at the highest temp thats till gives me clean sharp prints.
I get much stronger prints and no layer issues. I reckon that's one reason I have no problems with pla and other people claim it's weak and brittle. They're printing at too low a temperature.
Yes you can print pla at 180 - but try it at 210 and it's a far superior final material.
And while s3d does ahve alot of things to fiddle with. If you dn't fiddle - it works just as well as makerware - which also has a lot of things to fiddle with when you pick the custom profile option, just no explanation of what most of them do.
I've actually found that using notepad to edit the makerware profiles is much much easier than proftweak, which tends to randomly reset stuff and crashes a lot.
04-05-2016, 08:41 AM #4
^ This
I decide the heat setting for a filament when it stops clicking
I think alot of people (no one here, just in general) assume just because the last lot of PLA you had went well at 200c, doesn't mean the next lot will, same with ABS hey.. such a variance in temperatures. Although I do find for PLA 205c with really good cooling seems to be my magic number, unless printing at 0.05mm on the kossel, in which case i'll drop it to as low as I can possibly go, borderline.Hex3D - 3D Printing and Design http://www.hex3d.com
04-05-2016, 09:04 AM #5
