Results 11 to 20 of 22
03-02-2016, 02:13 AM #11
Manually with Simplify3D doesn't work? So you press Edit current process, and click the "Other" tab and have tried changing speed down there too?
if that doesn't work you can also try slic3r (not hard, just have to input the bed dimensions really. Slicer profiles do nothing other than change variables, so technically the gcode is the same for all machines that it pumps out, which is a pretty generic gcode, but the prints seem ok, it has pillar supplrt also like S3D.Hex3D - 3D Printing and Design http://www.hex3d.com
03-02-2016, 06:29 AM #12
The bulge almost disappeared after changing some JKN values and acceleration.
03-09-2016, 01:03 PM #13
- Aug 2015
- 256
Have you tried setting simplify to use random start points? I always get a visible seam if I don't check that box.
03-11-2016, 07:38 AM #14
After a lot of tests and calibration we found out that there is inconsistent movement to the X and Y rods.
This could be because of bearings or belts. Don't know yet.
Edit: Saw on a lot of forums that the movement should be "smooth" for the carriage but we can't measure that. Probably we have to disassemble each component to find out what makes the hiccups.
If anyone encountered the problem and resolved it please help.Last edited by Horia; 03-11-2016 at 07:44 AM.
03-14-2016, 01:13 PM #15
More troubleshooting:
click to enlarge
03-15-2016, 12:41 AM #16
Man, I have to be honest I think you are chasing dragons to an extent.. I have printers that cost me three times more than a flashforge and they leave a reasonable seam - and random seams are pretty ugly - but that being said if you can get rid of it, please tell us how.
I know this is an odd question, but all the shots so far have been of that same blue fliament, have you tried just for the hell of it, another type of filament? I know from experience the clear PLA and ABS can get rather goopy.Hex3D - 3D Printing and Design http://www.hex3d.com
03-15-2016, 05:01 AM #17
Yes, we used the same filament. I was talking about the bulge that appears after sharp corners. The Z seam is where we put it (on another face of the bag handle).
The story of our FFCP is a little complicated. We received the printer in october. We tested some models but after a few prints we realized something was wrong and sent it back. Before we sent it there was no bulge after sharp corners.
We got it back from the reseller with the problem fixed but now those bulges after sharp edges appeared.
This is the reason we are still dealing with this problem. Furthermore a few people printed the same models we did on their FFCP and they were spotless.
We will eventually change the Creator Series Filament (it's running out) and test other brands of PLA and ABS.
03-15-2016, 06:38 AM #18
I have no clue what's supposed to be wrong with that print.
What slicer software are you using ?
03-15-2016, 06:43 AM #19
Simplify 3D
The problem is that when I up the speed (as seen above the red line) there is a bulge appearing right after the sharp corner. That happens to all the prints.
03-15-2016, 03:56 PM #20
Crank up your JKN values. Higher speeds need higher values in those due to the greater speed changes.
