Results 1 to 10 of 12
Thread: Question about Quality of Prints
02-27-2016, 02:51 AM #1
- Feb 2016
Hey there,
I just found out about this printer today, and I have to say that I am amazed by the quality of the prints that I have seen from it. I was wondering how well it would do with D&D Style Miniatures? I am gonna put a link at the bottom of this to give you an idea of what I mean, but I was wondering if anyone had any experience with this size and detail level. I am seriously considering getting a 3D Printer, and it seems like this one would be the absolute best way to go for what I would need, and I am just hoping that it would be able to produce something like this. Please let me know what you guys think.
https://www.reapermini.com/OnlineSto...1/latest/77001
02-27-2016, 01:07 PM #2
- May 2014
- 17
I cant answer your question, but I have something else you might be interrested in, this guy has apparently moddeled the entire monsters manuel and 3d printed it http://imgur.com/a/57Ypa you can find some discussions about the prints and a link to a dropbox folder with alle the stl's for printing posted by the created in this reddit thread https://www.reddit.com/r/minipaintin..._dungeons_and/
and incase you are lazy here's the dropbox link
https://www.dropbox.com/sh/kzw6vw1y6...vRPI2re1a?dl=0
02-27-2016, 01:15 PM #3
- Feb 2016
Thanks for that. I guess my main question is what resolution will this print at? Is it at like .1mm or more or less? I am just wondering to see if this is the printer I would want to get, or if I should get something else like the Form 1+ that does down to 25 microns. I hope that doesn't make anyone here angry...
02-27-2016, 03:25 PM #4
Hey Forgotten_Avatar,
The Peachy Printer has a great level of detail but less accuracy.
Detail means, you will probably see all the small features of the 3D-model, as the resolution of the Peachy theoretically is really good (But you will need a quiet environment).
"Bad" accuracy means prints won't come out scaled perfectly. They might warp, skew, etc... (Depends on calibration)
This might be the better combination for you, as you don't need perfectly sized prints, but good looking ones.
Also you should remember that the Peachy isn't a printer made for easiest useability but for hackability so if you want to build it yourself then the peachy is exactly what you want.
Greetings,
quertz
02-27-2016, 03:46 PM #5
- Feb 2016
Thank quertz,
That really does help me with deciding. I have one final question, do you think that it would be able to do something of this detail level?
https://www.reapermini.com/OnlineSto...3/latest/77123
Thanks for all your help, and I hope to hear from you guys soon.
02-29-2016, 06:11 AM #6
you might want to have a look at this older update.
https://www.kickstarter.com/projects.../posts/1085300
Please remember that the peachy guys show the prints in a light that makes flaws as visible as possible,
plus this is not the latest version so this is the lower end for the quality you can expect from a well calibrated printer
Greetings,
quertz
02-29-2016, 06:07 PM #7
- Feb 2016
Thank you. Once I am able to purchase one, I will deffentally going to do that. Thank you so much for all the info on it.
03-11-2016, 01:56 AM #8
- Mar 2016
- Norway
Hi!
I wonder if the prints are solid, can you make gears with it?
Like those found in LEGO packages.
BR
Doc
03-11-2016, 03:24 AM #9
- nsw australia
- 81
it should be possible to create a solid print, OR if you are in a hurry a sealed shell of a print and then expose it ti uv/sunlight till it is solid
03-20-2016, 11:34 AM #10
- Mar 2016
- 68
Just a question on the 'sealed shell and cure later' suggestion... For that to work, you need a closed bottom and top, so the resin actually gets trapped, and no salt water can come in to displace the resin...
In the Cura settings thread (http://peachyprinter.ipbhost.com/ind...-printer-cura/) it says to print without a bottom, and then proceeds to suggest tilting the model, so the bottom gets printed...
I assume that for the sealed shell suggestion, you *would* want to print the bottom (and I am aware that would require a sufficiently slow drip that it actually can print that entire bottom...), correct?
