Thread: $99 Cowtech 3D Laser Scanner
02-12-2016, 12:59 AM #1
- Feb 2016
Our scanner was born out of the BQ Ciclop, an open source scanner using the same design and software as our scanner. We kept all the same basic functionality as the original BQ, but redesigned the scanner from the ground up, making several significant changes and adding many features.
First, we were able to slash prices by designing our own Arduino shield, using a more logical turntable bearing, purchasing our own laser cutter for the acrylic parts, and importing many of our components from reputable manufacturers overseas. We designed our printed parts to use significantly less filament and half the print time of the BQ version. Furthermore, we decreased the minimum bed size of the printer needed to print the parts to a measly 115mm(L) x 110mm(W) x 65mm(H) (4.5in x 4.3in x 2.6in), from a 6x9x3 required on the original. We focused a great deal of energy on aesthetic improvement as well, replacing the ugly and unwieldy threaded rod with sleek laser cut acrylic, adding a magnetic back cover to access the electronics, and an internal LED glow to make the scanner stand out in any environment.
The CT Ciclop scanner is a fully open source Rep Rap project, and all details will be released after the campaign is concluded.
We have launched the scanner on kickstarter:https://www.kickstarter.com/projects...rce-3d-scanner
If you have any questions feel free to ask!
