10-14-2013, 09:16 AM #1
Salt Water dissolving printed label??
I saw this posted on the comments section of the kickstarter project, but it's a really good point.
Wouldn't the salt water dissolve any half solidified layers of a partially printed layer if it came in contact with it?
Is there anything put in place to prevent this?
10-14-2013, 10:51 AM #2
- Oct 2013
What makes you think the salt water will dissolve the solidified layers? Who would use a resin that dissolves in the fluid that's used to suspend it?
10-15-2013, 08:03 AM #3
- Oct 2013
- 110
As above, the resin is not soluble in water. It floats on top, just like oil would.
In any case, it doesn't really matter. The partially printed layers happen at the top of the resin. The water is at the bottom of the resin. The only things that would cause the two to come into contact are:
(1) There's turbulence or waves in the print bath, causing water to slosh over the job. In this case your job is ruined anyway, because the Peachy relies on the top surface being flat.
(2) There is no resin layer because you've run out of resin. In this case the job can't be finished anyway.
Today, 04:18 AM in Tips, Tricks and Tech Help
