Results 11 to 14 of 14
Thread: Alternatives to chicken wire
02-10-2016, 11:46 AM #11
- Jan 2016
- 6
The idea of the pebbles is interesting. I wonder if sand would work as it is just a bunch of much smaller pebbles and still porous.
02-14-2016, 01:51 AM #12
- May 2015
- 15
A good cheap alternative would be to get some aluminum window screen at your local hardware store. easy to form into a base, with only a need to weight it to keep the prints down. some cheap fishing weights attached to the edges would handle that.
02-17-2016, 11:38 AM #13
- Sep 2013
- San Diego
- 210
Tried window screen, the print attaches like a barnacle!
02-17-2016, 11:48 AM #14
- Jan 2016
- 11
I am still liking the small wire mesh but in steel because after you remove the model it would be easy to recover the mesh by removing the printed "base". Also I would be able to make it into an inverted cone or tube so I could anchor supports to it if I find that those are needed. The main reason for wanting a smaller mesh is that it would add allot of flexability to designing supports and the base, you wouldn't have to worry to much about not attaching to a wire. JMHO
