Results 1 to 10 of 48
Thread: Nightmare start
03-31-2016, 05:38 PM #38
The original gear pictured Definitely Needed Cleaning !
The gear size and type must Match the design of the extruder and the Pulley in it.
The brass gear pictured has larger and Fewer teeth than the brass gears that came with ours
but I don't know if that makes much difference or not.
I think More teeth would help though.
The brass gear appears to have slightly larger outside diameter ?
If so, then I doubt the original gear would fit the new spring type extruder ?
Does the Gear Hit the Pulley ?
They should not touch each other when filament is going thru,
but should fit tightly together when No filament is between them.Last edited by EagleSeven; 03-31-2016 at 05:51 PM.
