Results 1 to 10 of 48
Thread: Nightmare start
01-21-2016, 07:34 AM #1
No, just a Dry cloth should get it off , when it starts to melt.
A little on outside of nozzles does not hurt anything, as long as it's not dripping off
I'm pretty sure the main problem was that the Layer-Height was too Low, if it was at .2
And temp was a little too high for PLA
01-21-2016, 07:42 AM #2
- Jan 2016
- 26
Yes definitely 0.2mm as I didn't change that from the default in Makerware... I'll up that 0.33mm put the temp down a bit to 205 degrees and give another attempt once clean..
Thanks a lot guys and I'll keep you informed how it goes!
01-21-2016, 08:00 AM #3
Yes, increasing height to .33 will let you know if that is the problem.
Then you can lower it a bit until you are happy with the results.
I've found that differences in nozzles require slightly different layer height and width settings.
(Not all .4mm nozzles are exactly .4mm, as an example)
