Results 81 to 84 of 84
12-08-2017, 01:24 AM #81
- May 2016
- Annapolis, MD
- 523
So I purchased a W04 version. I've not been able to configure it to work as the W03 version does. I am sending it back and just getting another W03. I got close, but the card's behavior was not reliable. I am sure it was some misconfiguration issue on my part, but I couldn't figure out what it was.
Update: Got another W03 version card and after my usual random walk through configuration, it works like a charm.Last edited by DaveB; 12-14-2017 at 06:52 PM.
05-10-2018, 03:35 PM #82
- Oct 2017
I'm sorry I didn't see your message before - the W-04 took me about 5 tries to get working, but it's been rock-solid ever since. The biggest thing is that you need to initialize it using the Toshiba software, I think. As annoying as it was to try to get it configured, once I got it working, it has handled being turned off, removed and reinserted, and lots of activity over the network and front panel, all without a single hiccup.
I'll report back whether my second one (which arrived yesterday) is as solid in my second Tech 1, once I've got it set up and working.
05-10-2018, 03:38 PM #83
- Oct 2017
Oh, and NEVER use the noise= setting...it will stop you from connecting EVERY TIME! It ends up reducing the effective wifi range too much to even reach an access point that's only 3-4 feet away, in my experience.
11-27-2018, 12:04 PM #84
