Results 1 to 10 of 24
01-07-2016, 12:55 AM #1
- Jan 2016
- 11
What do you mean? I didn't do anything special, just the usual thing, like filament type, nozzle 0.4mm.
And to be honest i don't have a case for my printer, i'm about to build one as my heated bed cant go over 100 celsius.
01-07-2016, 02:42 AM #2
Hi Whaitey, I think that while the advice of Lucky is good, you need to be a bit more systematic about all this.
I would suggest you to :
- first set precisely your Z0 gap, because otherwise any test you do on the flow rate will be biased by this. Do you have calibrated shims ?
- then set your flow rate right : there are tutorials for that.
- additionnaly, I would recommend checking your filament diameter, to be sure.
have a nice day
01-07-2016, 03:10 AM #3
