Thread: Strange X Homing Issue
01-02-2016, 10:25 PM #1
- Jan 2016
Hello,
I've got a Powerspec 3D Pro (same as Flashforge Creator Pro). It's been working great for about a year. I just started having a strange problem with homing. When it tries to home, it keeps trying to go in the X direction after it hits the limit switch. At first I thought the limit switch was bad, but if I try to jog, the limit switch works fine for any Y that's about the front 3/4's of the printer. On the back quarter (approx), it won't honor the limit and tries to skip the belt. The light on the X limit switch still lights up when X gets to the edge no matter what Y position it's in. I tried manually pushing the X limit and I get the same results (won't jog if Y's in front 3/4, will still jog toward back). Has anyone else seen something similar? Any ideas on how I could troubleshoot?
Thanks!
01-03-2016, 08:14 AM #2
Sounds like it might be a bad wire or connection.
If it works for part of the area, but when it retracts backwards, the wire/connection could be separating enough to cause an open circuit.
I would check the wires going to the limit switch and the connections to the switch and main board.
01-03-2016, 01:19 PM #3
- Jan 2016
01-03-2016, 02:32 PM #4
Sounds like a faulty end stop cable. A common problem. Replace it you'll be fine...
