Results 31 to 36 of 36
12-19-2015, 08:12 AM #31
1) You are probably correct on me confusing the guy..
2) Thanks for the detail, I do understand the reasons for mortality as it relates to death by electrocution and is the reason why I said "The body type, and area of body being effected.." However you are simply wrong when you make statements like "you need at least 50 volts for it to flow through a human". Forget all the safety training I've had that says otherwise, I have felt it first hand. All it took was a knee on damp concrete and my hand bumping a 12vac relay signal (high voltage was off, but control circuits were still powered) to get my attention REAL fast.
12-19-2015, 08:32 AM #32
- Burnley, UK
- 1,662
If you are going to quote me please quote me correctly.
The statement "you need at least 50 volts for it to flow through a human" is not complete. Please learn to read and reply in a sensible manner if oyu are going to bother replying at all.
I am not trying to educate you I am trying to help the guy with the problem. It seems to me that you cannot be educated as you seem to think you know everything.
Here is my reason for knowing what I am talking about. I have a first class honour degree in electronics. I have a Phd in electronics specifically in the area of electricity distribution networks. I have worked for 25 years in the electricity utility field.
Now I have finished with this thread, I will not post again. You obviously know everything so you fix it but I would appreciate it if you did not kill the guy.
12-19-2015, 09:21 AM #33
Why so defensive? I wasn't challenging your intelligence, but hey if it makes you feel better to attack others in an internet conversation because people don't agree, well..... As for "...I would appreciate it if you did not kill the guy." you do realize that he built from kit right?
12-19-2015, 10:11 AM #34
IN situations like this I give my mate acall - he's an industrial electrician and he'll fix it.
So if you don't know what you are doing - find someone who does and let them get electrocuted instead of you :-)
12-19-2015, 10:25 AM #35
Here's one for you LOL
another...
Another... I have a feeling, this is Mjolinor feelings toward us (me specifically)... (It's a joke Mjolinor, I'm just kidding......)
main-qimg-078d16509bf1ce60db42bc6df0fdfc0f.jpgLast edited by ServiceXp; 12-19-2015 at 10:35 AM.
12-21-2015, 11:45 PM #36
- Dec 2015
Just a thought here, I'm not an electrician or EE but have maintained a house for 40 years...
Try plugging your printer into a different circuit than you are currently using (i.e. one in a completely different part of the house not on the same breaker). You may have a hot and neutral or neutral and ground crossed somewhere in the circuit. I had a similar problem once- a slight but definite tingle while touching a light fixture housing during a bulb change. Took me a long time to find the culprit, but a neutral had worn off insulation in a bathroom exhaust fan due to vibration and was touching the metal housing.
Could be something as simple as changing the circuit you are using could fix the problem with your printer.
