12-05-2015, 08:15 AM #1
Did you clean the guide-Tube, that connects Nozzle to mounting-block ?
(I use a brass-wire, the same size as inside of Tube, to push out everything, after it is heated)
If that is clean and the nozzle Temp is not changing (cooling for some reason),
then it must be binding somewhere at spool or guides from spool ?
12-08-2015, 03:20 PM #2
- Sep 2015
- England
Ok i took the nozzles off and destroyed both them Teflon guide tubes and had to buy some more.
Received to new Teflon tube today and fitted to both extruder's then did a bed levelling and then on to a print and omfgg its printing fine haha
what im confused about is why it could load and extrude filament, but not print anything, anyway its all working now, Thanks EagleSeven you have been a great help mate
12-08-2015, 03:58 PM #3
The guide-Tubes we use do Not have Teflon inserts in them, and Never had any,
they work great and are easy to clean, without any possible damage.
From what I've read, the type tubes that have Teflon in them Cause more Trouble, than they help !
But we've never used the type with Teflon, so I'm no expert about that.
I just Know that the tubes without Teflon work great,
as long as you keep a brass-wire handy to clean them out when needed !
12-09-2015, 07:11 AM #4
- Sep 2015
- England
