Results 1 to 8 of 8
  1. #1
    Technologist Ward's Avatar
    Aug 2015
    Odd Printing Question
    I have a FFCP clone.
    It will only print up to 8.9" height x 5.7" width x 5.9" length
    Unfortunately I would like to print something that is long and flat 6.5" long x 3.5" wide x .125 thick"
    Since I obviously do not have the width needed, what would happen if I tried to print that object On EDGE ?
    I'm assuming I would have warp city and it'd be about as wavy as the surf on a windy day.
    Do I have no choice but to buy a 2nd 3D printer with a larger build volume to get that extra .6 inches?
  2. #2
    Split your article in two or more parts print and them separately. Then you can join then later.
  3. #3
    Engineer-in-Training ssayer's Avatar
    Oct 2014
    Location
    Lakeville, Michigan
    You can most certainly print it without cutting it. Just rotate it on the bed (something like 30°) I believe...
  4. #4
    Quote Originally Posted by Ward View Post
    Just rotate the object to fit the bed-space diagonally , in the slicer software, if it will fit that way ?
    Go to this thread, to see what I did to solve those problems:
    http://3dprintboard.com/showthread.p...ender-brackets
    Our bed is now 11" long.
    (There's a picture of the extenders in that thread but you must click the website's hidden-pages to see it ! ??? )
  5. #5
    Technologist Bobby Lin's Avatar
    Aug 2015
    Location
    Melbourne, Australia
    Follow Bobby Lin On Twitter Add Bobby Lin on Facebook Add Bobby Lin on Google+
    You can have it printed separately then assemble them afterwards.
  6. #6
    Student
    Oct 2015
    Location
    shenzhen
    Follow stronghero3d On Twitter Add stronghero3d on Facebook Add stronghero3d on Google+ Add stronghero3d on Thingiverse
    I know can improve the "config" file of print area/size in makerware file folder, and then just put a glass on top of the heat plate.
  7. #7
    Sep 2014
    Location
    Brummen, Netherlands
    You are mixing up your X,Y and Z dimensions.
    The FFCP has a print bed of 8.9" width (X-direction) by 5.7" deep (Y-direction) and can print up to a height of 5.9" (Z-direction).
    Your object fits perfectly on your printbed with room to spare in all directions????
  8. #8
    Jul 2014
    you've got the dimensions the wrong way round.
    It's because americans always put numbers in the wrong order.
    so it's actually 8.9 long by 6 wide by 6 high.
    so: 6.5" long x 3.5" wide x .125 thick"
    will fit on the bed without any problems.
