Thread: 2d gcode?
11-24-2015, 08:48 AM #1
2d gcode?
I do a lot of RC sailboat racing, and new hull's for some classes of boats can get mighty pricey (There are RG65 CF hulls that cost upwards of $4,000, and they're less than a meter long and just the hull, nothing else!), and I'd like to design some of my own.
One common (manual) technique is take a hull design, and cut it into layers, then you'd cut each layer out of a layer of styrofoam, glue the layers together and then sand it smooth. The resulting shape can be used for a wood plank, Vacuum formed, CF, or other material mold.
I'd like to be able to take a (relatively) simple x/y gantry and attach a pen to it to trace out the layers to be cut. Eventually it would be upgraded to a laser to cut the foam.
But right now, I'm just looking at software. What programs would you recommend to use to design and then export 2d gcode? I was thinking something like Ramps to run the plotter/burner.
11-24-2015, 08:55 AM #2
- Jun 2014
- Burnley, UK
- 1,662
I would think that with a bit of messing some slicers could do this. If you set the layer height to 30mm then your Gcode file will have exactly what you need in it.
I have ramps in both my laser cutter and my CNC mill. I use Inkscape to make the laser files but it is 2D only I think.
11-24-2015, 09:14 AM #3
- Sep 2015
- San Pedro, CA
- 66
11-24-2015, 10:25 AM #4
- Jun 2014
- Burnley, UK
- 1,662
Cura lets you do it. Can't say my models look any good with only one or two slices but I guess that is what one should expect.
Yesterday, 02:02 PM in Tips, Tricks and Tech Help
