Thread: e3d nozzle jam. My fault?
11-22-2015, 04:08 PM #1
- Dec 2014
This is my first time printing on a newly built printer, so I'm wondering what I did wrong. .40mm e3dv6 nozzle heated to 250degC, starting extruding 3mm ABS at 15mm/s. Within 30 seconds the filament stopped feeding, and when I retracted it the nozzle was jammed.
Disassembled, confirmed the heat break was free and clear, with the plastic stuck solid in the nozzle. What could I have done to cause this "hollow" jam?
I'm currently switching over to the magma hotend while this soaks in acetone.
11-22-2015, 08:43 PM #2
You can read this article to solve your problem about nozzle jam. Let me know if this works for you.
11-24-2015, 08:20 PM #3
- Dec 2014
Still working on getting a sewing needle through it, been soaking for 48 hours. . Thank you for the link
11-24-2015, 10:30 PM #4
- Feb 2015
- 371
When I get a huge jam I use a torch and burn the jam out.
11-25-2015, 12:25 AM #5
- Feb 2015
- 211
Heat gun works just as well without the flame.
11-25-2015, 01:15 AM #6
- Sep 2014
- Brummen, Netherlands
- 265
If the former, you are trying to extrude (1.5^2)*PI*15=106 mm3/s which is way too much for any hotend I know of.
