11-02-2015, 02:02 PM #1
- Dec 2014
- 11
Holes in top layer of model, makes my students melancholy
I am running a Powerspec 3D Pro (private label clone of Flashforge Creator Pro) with 1.7 ABS, .2 layer height, 50 speed. I use maker desktop software. I am getting holes in the top of my prints. I just finished the pyramid below to check all of the flat surfaces a pyramid can offer. All of the parts print well except for the top. Things I have tried are
- Infill from 15% (my default) up to 70%
- Speed down to 30
- temperature from 225 to 240 in 5 degree increments
- minimum layer time of 15 seconds (from the default of 5)
- Cleaned nozzle to make sure there wasn't obstruction
Not much difference found from my changes. I have this problem across multiple models using multiple colors of filament. Things I have considered:
- Under extrusion. However, all surfaces other than top layer print fine.
- More fans? This model has a 40mm fan that blows on the hotend.
Any suggestions would be welcomed. Please help
11-02-2015, 02:22 PM #2
- Sep 2014
- Brummen, Netherlands
- 265
Either something strange in the STL file, or the slicer is making errors (assuming that the slicer settings are OK)?
Which slicer are you using?
11-02-2015, 02:45 PM #3
- Dec 2014
- 11
Am using the built in slicer in MakerDesktop, they use makerbot slicer. I have tried different infills and layer heights to see if I could shake something loose in the slicer. Guess I could load replicatorG and see if that changes anything.
it does this on every model, not just a specific .stl file.
Nathan
11-02-2015, 03:25 PM #4
- Dec 2014
- 11
Could it be something with X offset? Possibly raising the hot end between layers? Any feedback?
