Results 1 to 10 of 26
Thread: Showcase prints?
10-22-2015, 03:33 PM #1
- Oct 2015
- 28
Showcase prints?
Hey! Would be cool to see how your prints have turned out, especially if you've used non new matter store stl-files and / or used some other filament than the new matter one.
So for the few of you that have received your printers - Please share
10-22-2015, 04:36 PM #2
- May 2014
- 16
Printed this Frankenstein light switch plate...
http://www.thingiverse.com/thing:649284
Printed with Inland silver PLA from MicroCenter.
Spool fits well on the holder and turns easily. Same size as sample Mew Matter Roll, except deeper (1kg)
I printed this by uploading the STL to my library, so it used all New Matter settings. Temp was fine.
I have also printed by uploading GCode from Cura through the desktop utility. Some models I have are support free, and the New Matter slicer added support in the middle of parts that don't need it, making holes for attaching pins difficult to clean.
I am very happy so far.
1st pic no flash, second pic flash.
10-23-2015, 06:06 AM #3
10-23-2015, 09:28 AM #4
- Oct 2015
- 28
10-23-2015, 12:31 PM #5
- May 2014
- 16
The Inland "silver" is pretty much a grey. Hatchbox silver PLA is a bit darker, and more silvery.
I didn't do any post processing Came off the printer like that. It did have support under the plate, as there is a recess in the middle over the switch, so I removed those, but thats it. I did have to glue back one of the small prongs that broke while removing it from the bed. But that is probably a PLA thing, more than a printer thing. More brittle, and parts made vertically will always be weaker due to the layers.
10-25-2015, 04:37 PM #6
- Oct 2015
- 28
10-25-2015, 04:47 PM #7
- May 2014
- 16
New Matter posted some settings in their FAQs on the website.
http://support.newmatter.com/
Basic machine settings to set up the right machine, and Start/End code to add (theres a tab in Cura for that) that adds the same calibration as New Matter software.
10-27-2015, 11:00 PM #8
- Mar 2015
- California
- 10
Here is a test part I made to see if the printer could print to its claimed envelope (150mm x 100mm x 125mm).
https://instagram.com/p/8jnVnjLG2_/
10-28-2015, 12:23 PM #9
10-28-2015, 12:54 PM #10
- Oct 2015
- 12
The prints definitely can use some tuning. The overall surface quality is kind of like felt.
