Results 1 to 10 of 101
Thread: I need some serious help
10-15-2015, 01:29 AM #3
- Oct 2015
- Great Falls Montana
- 52
I will definatly read up on what you have linked. The nozzle may very well be dead , but its the hotend itself that has croaked. After posting I decided to take it back apart for the 3rd time tonight, because the fliement was not even making it thru the throat. In the process the set screw that holds the heating element stripped and the head broke off ( homemade set screw because they didnt send one with printer) guess it couldnt take the heat.
Anyway , im a little overwhelmed at how many different types there are out there. I need a hotend that will fit on this printer and cheap (as possible). Would you be able to direct me to one for my printer?
Im also thinking about disassembling the printer and make sure that everything is square. your thoughts?
Lastly , when i went thru the guide that came with this thing I did the manual leveling and the last step wanted me to adjust the smoothing offset ( make center height match tower heights) anyway I could get no changes. When I do the autoleveling , it seemed to make no difference. the prints that i got worked , but in spots it seemed to smear the extruded filament.... so to close in those spots im assuming. Again your thoughts?
Thank you for your post , im feeling a bit more confident. Still need a new hotend though
