Results 11 to 19 of 19
10-10-2015, 05:02 PM #11
Fixed it, thanks!
Tho I remove the second extruder, as I havent used dual printing. Less weight to drag around
Didn't want to hassle with positioning the extruders, seems like it's difficult to get perfect height on both.
10-10-2015, 05:18 PM #12
10-10-2015, 05:33 PM #13
yup!
Also after around 500 hours printing the PTFE tube was very bad. Actually had the shape of the nozzle, and was black...
10-10-2015, 05:57 PM #14
- Burnley, UK
- 1,662
I went from smooth to fully threaded having failed completely to get the non-threaded part out of the aluminium bar. The threaded ones do not stick.
10-13-2015, 01:19 PM #15
that's a really clean heat block :-)
Mine tend to have bits of plastic all over them.
10-13-2015, 02:32 PM #16
I found that when the extruder Temp was too High the filament could Boil
and get on outside of nozzle and block.
That's when I discovered that nozzles were getting Hotter than indicated at printer's display.
And used digital thermometer to get Actual Temps at nozzles.
(averaged about 15 C error)
Then lowered setting for correct temp.
I'm not saying you are having same problem but someone out there may have that problem ?
It seems that many people set and leave the temp Way too High anyway !Last edited by EagleSeven; 10-13-2015 at 02:40 PM.
10-15-2015, 08:27 AM #17
- Dec 2014
- 42
I had this same problem with mine when I pulled the extruder tip to clear a clog. The whole block shifted and because loose on the shaft it was screwed in to and returning it to its normal position didnt tighten it any.
So right or wrong, I removed the set screw and pulled the whole shaft out and tightened that into the heating block all the way using a pair of needle nose pliers. From there, I used an adjustable wrench to hold the block while I used a socket to reinstall the extruder tip.
Then I put shaft/heater block back to where I thought it was and tightened the set screw. Then I just re-leveled the bed and it prints good now.
I also pulled my 2nd stepper motor off mine, too. I left the extruder and heat block installed because I was too lazy to pull the wires out of the loom. I also redirected the other fan to blow on the working extruder, too.
Like you, I figured less weight would lead to longer lifetimes on the belts and wearable parts.
10-17-2015, 01:00 AM #18
- Feb 2015
- 91
Less weight also means prettier prints. Less moving mass means less backlash around the corners. So you can go faster (and turn up your acceleration) and still get a smooth finish. Or so I've heard.
10-17-2015, 01:38 PM #19
