Results 1 to 10 of 15
Thread: Just ordered my CTC :D
10-12-2015, 12:51 AM #1
- 441
Yeah nevermind on that, I got it on there and am using it. Still working on getting a Z axis stabilizer and some rubber feet. The bed plate on this thing is pretty bowed when heated, quite annoying trying to do full bed things in ABS. I currently have a replacement heating bed for my Flashforge creator pro coming in the mail, so I want to take my old flashforge bed (it needs new heating wires soldered onto it with a new wire) and replace it on this CTC. This should be possible right? I believe my biggest issue is it will need a different bracket to use with the flashforge bed, because it is a 3 screw instead of a 4 screw leveling system.
Also I would like to get spring loaded extruders put on. I was wondering, I don't use my left extruder on my flashforge. I could probably swap it onto the CTC, but would it have to be on the left side? I'm thinking so.....
10-12-2015, 08:08 AM #2
10-12-2015, 09:01 AM #3
- 441
Well mainly because I will have an extra flashforge creator pro bed plate laying around and I have no glass currently :P Its a much thicker bed plate, never had any problems with it other than it quit heating. Easy to level. Ect. Although if I can find a cheap enough sheet of glass around where I live, I may do that for a bit. The one place I called around me wanted $60 for a piece of borosilicate glass cut to size. So obviously not going to that guy. But yeah the main issue is the warp in the middle of that plate. Also I realized the LED is not even turning on with this CTC, so after work today I gotta go through and see whats up with that.
10-12-2015, 09:32 AM #4
We got 2ea 6"x9" glass sheets cut from a 10"x12"x3/32" piece,
at Lowes-hardware for about $3.
It's Good quality glass.
When I added the Extenders we had to cut 2 of those 10"x12" sheets,
so cost for those was $6.
