Thread: very small request for you all
09-15-2015, 08:15 AM #1
- Sep 2015
2 years ago the audio jack for my laptop broke. It was really just a piece of plastic that held the audio input in, so it still works, but now I have to have a separate USB plug in to use audio stuff. It really sucks.
I got an idea this morning, since only God knows where that piece of plastic chipped off is, what if I could 3-D print the small bit of plastic?
My school has a 3-D printer, so I could print it myself, I just would like someone to actually design it for me. It's very small, so it shouldn't be that hard.
I don't need a piece that perfectly fits into the broken part, just something that would hold it in place. I have some pictures to visualize it:
Right now I do not have the measurements because I haven't had a chance to measure iti. Once I get the chance I will though. I plan to take apart my computer and take it out for exact measurements. All I need is something to cover the broken part to make it complete it a full circle, you know?
I know this isn't enough info to work off of, but I will post more soon (measurements and stuff).
I'm sure this is possible, but I just want to know if someone is willing to help me with this.
Thanks for reading and have a good day.
09-15-2015, 10:07 AM #2
I see (at least) one problem with this request. If I'm trying to print a circular object, especially small openings like this, there is some amount of shrinkage the ABS I sue goes through, so It may take 2-4 tries before a part fits correctly. Others using other systems may not have this issue. I also have issue printing things that small. Want a bigger enclosure with that jack in it? Sure, but just that ring would be an issue for me. Again, others with better equipment may have better results.
My first inclination would be to open up the lap and see exactly what type of jack it is. I'm assuming it's a 3.5mm jack. Look on ebay for the identical part, buy that, and replace it. It shouldn't cost more than a buck or two. But, you'll need to be able to solder to do it. That's the way I would attempt this.
My second approach would be to fashion a new ring by getting a piece of plastic as thick as the broken edge is deep. Drill a hole the size of the jack , and then cut it out so it's just slightly bigger than the part to fix. Then with a hobby knife, slowly shave off tiny pieces until it fits correctly. Then use a good plastics glue or epoxy to secure it in place.
My third approach would to use hot glue. Put a small bead on the broken part, and then trim it back until you get the fit you want. Downside is if you get glue into the opening, may cause problems trying to get it out.
09-15-2015, 10:34 AM #3
- Sep 2015
09-16-2015, 03:00 PM #4
- Sep 2015
keeping in mind this is only my second post on this forum and the very first was also asking for help just a few minutes ago...
why not get some clay and press it in to mold the exact shape you need. then remove it, let it dry and scan it in and 3d print that??
09-17-2015, 02:46 PM #5
Well, personally I wouldn't bother. I feel you are over thinking this and trying to tap dance in hunting boots. 3D printing is simply the wrong tool for the job.
Go to Home Depot or other hardware store and buy this (or similar):
You can repair the part very easily. After the repair, you can paint it to match the surrounding (apparently black).
09-20-2015, 03:20 PM #6
09-21-2015, 01:33 PM #7
Didn't know they had black. Never seen it on the shelf. Never looked though
