Results 1 to 9 of 9
Thread: Geeetech G2s Printer Kit Review
09-27-2015, 09:11 PM #3
- Sep 2015
- 7
Geeetech G2s - Share your knowledge!
If you have any workaround for the G2/G2s, please add them to the Wiki page I'm maintaining on reprap.org:
http://reprap.org/wiki/Delta_Rostock_mini_G2s
I've included fixes for a bunch of mechanical issues, including:
Mechanical Rigidity:
* Ensure the frame is rigid - if not, add washers to the smooth rods
* If you have a "wiggly spider", buy or print out the shim washers for the rod-end holders.
Frame
* If you can't finger-tighten the 4mm bolts into the smooth rods, don't force them - the blind thread may be too short. Use washers to shim up the bolt instead.
Belt Jams:
* Make sure both set screws in the driving pulley are secured.
* Make sure the idler pulley wingnuts are fully secured.
* Add idler pulley washers.
Homing Issues:
* Verify that you are on the correct pins for your endstops (see end of manual for correct pinout - earlier photos in the manual are incorrect!)
* Separate and twist the endstop wires to prevent false homing triggers
Bed Levelling
* Put lock washers under the bed wingnuts, so that you can adjust the bed from the top using the allen bolts.
* Ignore the autolevel feature for now - the printed guide for the probe can be too tight (or loose), and cause a head crash on autolevel.
PEEK J-Head
* Verify that the teflon guide is the correct length (if your PEEK cylinder is touching your heating block, it's too short!)
* Heat-tighten the PEEK heads to prevent leaks
* G2s: Align the nozzles to prevent interference during prints
Extruder:
* If you are getting under-extrusion (unexpected random holes in your print), make sure the Mk-8 extruder's tension is set correctly.
PLA Specific:
* Put a fan next to the bed to improving bridging and prevent blobbiness
ABS Specific:
* Use the correct Beta (3950) for your thermistor, and PID tune it (someone with Marlin experience can expand on this) - otherwise the PEEK heads will melt with the default firmware at 240C
* Add insulation under the heat bed to prevent heat loss
