Thread: Tube Clamps for Super Fly
08-30-2015, 05:31 PM #1
Here are some tube clamp files. The original Prusa tube clamps definition in .SCAD and a set of 4 different sized clamps as an .STL file. If you print the .STL file, probably, only one of the clamps is suitable for you. But once you know the one that works, you can just delete the other ones and print as many as you need.
tube_clamp 6.5 (0.25 tubing) x4 (not stacked).scad
tube_clamps_assorted_sizes.stl
I'm not sure if you will be able to download the .STL file with the clamps already made. If not, Install OpenScad and Compile/Render the .SCAD file to produce the clamps. (You export the Compile/Render as an .STL file) One of those clamps will work for you.Last edited by Roxy; 08-30-2015 at 05:36 PM.
09-02-2015, 05:02 PM #2
Here is an archive file with the full source (all include files) and the .STL file generated from the compiled and rendered source.
Enjoy...
