Results 21 to 30 of 30
Thread: Printer to replace Z18
07-28-2015, 08:56 AM #21
07-30-2015, 02:23 PM #22
show me a video of a printer running at 200mm/s .
And producing a useable print.
That's just ridiculously fast. How do you get the plastic set fast enough ?
Ninjaflex is usually printed at around 20-40 mm/s max. Slower is usually better.
08-02-2015, 11:46 PM #23
- 349
If the printed parts are for end-use, then consider PET filament, which is stronger that PLA or ABS. And it does not need an enclosure, and can be done without a heated bed with the right filament. This opens up the options of printer greatly, to solid ones like the F306 core-xy printer.
08-10-2015, 05:04 AM #24
Sorry, aardvark
I‘m back. And I took three short videos of 200mm/s printing, please check them on Youtube:
https://youtu.be/zPEMH8YL7Tw
https://youtu.be/8jzT3F6ii-s
https://youtu.be/QUoQJx6kwm0
To print with a very high speed, I set a much higher nozzle temperature at 240 degrees, in this way the filament can be melt as soon as possible.
And yes, NinjaFlex needs a slower speed, And I have printed PolyFlex at 45mm/s with my Mankati Fullscale XT Plus, and the result is great!
08-10-2015, 05:16 AM #25
08-10-2015, 01:17 PM #26
- Aug 2014
- Montreal, Quebec
- 576
Why after watching the 3 link, it does not feel 200mm/s print?
Because for me it is clearly between 50 to 100mm/s. The perimeter print is too slow for being 200, can't say about the infil, since the thickness is not that big.
But I am curious about your double extruder setting, did you use paper to calibrate both height?
Oh and dont upload pic on this forum, cuz it sucks lol. Upload on some 3D party hosting and link them, it is far better.Last edited by richardphat; 08-10-2015 at 01:23 PM.
08-10-2015, 09:59 PM #27
http://imgur.com/gallery/amieGDE/new
http://imgur.com/gallery/IvwEFRr/new
I find that the main print speed in basic setting is not a absolute value for the whole printing,
let me change the inner shell speed, out shell speed and infill speed to 200 mm/s and try again.
08-10-2015, 10:09 PM #28
I tried again, the printer did not speed up very much.
It seems that the firmware limited the top speed.
Advanced setting:
http://i.imgur.com/x2vWGqz.png
Printing video:
https://youtu.be/-cur1bPCW-g
08-10-2015, 10:24 PM #29
Hi, Richard
I calibrate the left nozzle with a card, and the right nozzle is a little higher than the left one, about 0.1 mm higher, I judge it with eyes... and it works good.
When printing with dual filament, the 0.1 mm higher right nozzle works as good as the left one, and it won't impact the object.
08-22-2015, 03:33 PM #30
