07-15-2015, 06:29 AM #1
Wanhao Duplicator 5S ! - 3D Markt
- Fitted with its own WanhaoMaker Software
- Huge Building Volume of 37.8 litres!
- Increasing Printing speed- 300mm per second
- Contains 0.02mm Resolution
- 1Year Full Factory Warranty
Referred to as one of the largest desktop 3D printers in the world, the new and improved Wanhao Duplicator 5S surpasses itself and succeeds in providing the user with a superfast 3D printing service.
Capable of printing up to an amazing 37.8 litres in volume, the Wanhao Duplicator 5S allows the user to print products in a range of sizes and without question get value for their money.
Fitted with its own dedicated WanhaoMaker software, this top of the range printer an adjustable layer thickness from 0.02mm – 0.4mm, which is a necessity in order to print some epic detailed 3D products.
Printing big has finally been made easy! Don’t miss out and pick up yours today!!
Advanced features:
• Massive building volume: 305*205*605mm
• One of the fastest 3-D printers in the world, you can even adjust the printing speed during printing!
• Layer thickness: Choose 0.02 – 0.4 mm which is adjustable by included software.
• High performance, patented extruder, no clogging problem
• Built-in memory, off-line printing available, any interrupt is ok during printing.
• All-steel frame work, super long service life
• Industrial-grade motion system, high stability and precision
• Speed: 20 – 300 mm/s
• Positioning precision: 2.5 micron on Z axis, 11 micron on XY axis.
• Overall dimensions: 460 x 400 x 860 mm
• Shipping weight: kg (88 lbs) 39
• Linear ball bearings
• 4x20 LCD character display and turning and press control pad
Printing Specifications
Printing technology FFF Fused Filament Fabrication
Extruders 1 Single Extruder
Interface Print with SD Card or direct via USB Port
Build volume 305 x 205 x 605 mm, about 37,8 l
Layer resolution 0.02mm - 0.4mm
Print speed 20-300 mm/s
Position precision X, Y Axis 0.01mm
LCD Display 4x20 LCD character display and multi-direction control pad
Operating nozzle temperature Recommended Maximum 230 C
Stock nozzle diameter 0.4 mm
Flow Rate Approx 200 cc/hr
Platform temperature NA
Supported materials Prints PLA, PET
Filament diameter 3.0+-0.1mm
Connections USB, SD Card slot
Chassi Extreme XV Rock Steel structure
For more information please e-mail us at info@3dmarkt.at or checkout our website www.3Dmarkt.at
The following product can also be found on ebay http://www.ebay.com/usr/3dmarkt?_trksid=p2047675.l2559
You can also Find us on Facebook https://www.facebook.com/3DMarkt?fref=ts
