Results 1 to 10 of 14
01-05-2016, 01:03 PM #1
- Jan 2016
It looks like you made the cylinder "block" in 2 pieces, how hard were they to align? Would you be willing to share your stl files?
thanks,
Matt
01-05-2016, 03:38 PM #2
- Jul 2015
Hi Matt,
The cylinder block was printed in one piece (not counting the caps). I attached a zip of the files. Sorry it is so disorganized. I designed it in FreeCAD, so you can open the design file in that to see the assembly. The aluminum rod used for the crank shaft and vertical supports is 1/4", available at any hardware store. I believe the screws for the caps were 4-40 and the rest were 6-32. I'll be happy to answer any questions you have.
Geoffrey Schulz
01-05-2016, 03:45 PM #3
- Jan 2016
01-05-2016, 05:36 PM #4
- Jul 2015
I think the tallest part is about 3 1/4 inches, and the largest by area is the base, which is about 3" X 4 1/4". All the parts were designed to print without support material. The cylinder, valves and piston rod are designed to print vertically, all the rest will print horizontally. I have a 8" X 12" bed (Airwolf XL), so I can print the entire engine in one pass, but regardless of size, you should be able to print this. My son has a simple XYZ Jr and it will print on his machine.
01-28-2018, 03:58 PM #5
- Jan 2018
https://2018grammys.net/
Grammy Awards
Grammys 2018
Grammy Awards 2018
Grammys
The Grammys
Grammy Winners
Grammy Nominations
Grammy Awards Live
Grammys 2018 Live
Grammy Awards 2018 Live
Grammys Live
The Grammys Live
Grammy Winners Live
Grammy Nominations Live
Grammy Awards Live Stream
Grammys 2018 Live Stream
Grammy Awards 2018 Live Stream
Grammys Live Stream
The Grammys Live Stream
Grammy Winners Live Stream
Grammy Nominations Live Stream
Watch Grammy Awards Live Online
Watch Grammys 2018 Live Online
Watch Grammy Awards 2018 Live Online
Watch Grammys Live Online
Watch The Grammys Live Online
Watch Grammy Winners Live Online
Watch Grammy Nominations Live Online
