Results 21 to 29 of 29
08-16-2015, 08:24 AM #21
- Jul 2015
- 29
You can use the button of Identify to show the number of the screen.
So you can tell which is you desktop and which is belong to the scanner.
and the screen of your PC, need to be the mainscreen.
mainscreen should be on the left, second one be the left next to the main one.
their upside need to be in one line.
and you needn't set the mainscreen to 800x600.
Thanks.
08-16-2015, 08:32 AM #22
- Jul 2015
- 29
Please make sure the Mac has discrete video card, if not ,I am not sure it will work.
With Windows, we can see from the device manager.
There is a item called Display adaptors, if you can't find other device except Intel's.
It means it has not discrete video card.
And you need change to another pc.
08-16-2015, 10:04 AM #23
Alfred or Yang
All MacBook Pro have discrete cards built in, and mine has a Radeon 6750M. The only ones that don't are the ones that start with and only have Intel HD graphics listed in their specifications.
This extra card allow you to drive an additional monitor (or your VGA projector in your scanner), but you have to use a Mini DisplayPort adapter to access this ability. In my case the MacBook has a Thunderbolt port, and the right adapter will get you a VGA output!
This is the screen you need to see in Windows 8.1, and it's accessed via PC settings>PC and devices>Display. As long as you see a set up like this, display 2 being 800x600 60Hz (set under Advanced Settings), then you are good to go.
Also as Hugues said, you need to use the Extend these displays setting too.
Your instructions were slightly confusing, more so for me, as I didn't understand the operation of your scanner. However, now that I do, I know I can use an older 27" iMac with your scanner, as well as a later version, another screen, plus your scanner in a daisy chain!
My next task will be to get a legacy iMac to work, and we'll see what else I'll manage too.
Hope this helps you guys
Here's a test scan
Mike
08-16-2015, 08:00 PM #24
- Jul 2015
- 29
Good news, and any problem you have met, you can cotact me.
my email is yangjianlong@shining3d.com
08-25-2015, 02:44 PM #25
Hi 24c,
I have the very same early 2011 MBP with the same VGA cards but when I installed the Bootcamp drivers on the windows 8.1 the screen blacked out and I had to delete the Radeon drivers in safe mode to have picture plus sound is not working at all . What version of windows do you have and what kind of drivers are you using? I decided to switch to parallels even though a virtual windows is weaker, do you think my Einscan gona work on parallels? thanks
08-25-2015, 08:18 PM #26
- Jul 2015
- 29
win7 64bit\win 8 64bit\win 10 64bit
bootcamp is designed for mac with cpu of intel.
08-26-2015, 01:17 AM #27
Harry,
I have Windows 8.1 Pro, but updated the BootCamp to the latest version from the Apple website...just booting up now in OS X to get the version number. It was BootCamp 5 with the 31 January 2014 date for the folders. There was an update from the BootCamp that came with my 2011 MacBook Pro, and it something like 5.1xxxxx. https://support.apple.com/kb/DL1720?locale=en_US
I never had a black screen, until the initial start up just before the Windows 8.1 logo comes on screen. I had everything unplugged at the install, only added stuff after completed.
Hope this helps
Mike
08-26-2015, 04:29 AM #28
[QUOTE=24c;66572]Harry,
Thanks Mike, so you would recommend running the scanner on windows 8.1 pro under Bootcamp 5.1.5621 rather than on Parallels 10 or 11?
08-26-2015, 05:02 AM #29
Hi again,
Yes Harry, we both (Hugues & I) know this works...and it behaves as expected. If your MacBook is older like mine, and I think you said it was, then you can't use 10 according to the Apple website.I replied to your other thread too.
Mike
