06-24-2015, 12:50 AM #6
- Sep 2014
- 28
Ok, I ran a Ctrl V Print, and I got lots of stringing, and didn't like the detail. On that print I took printbus's advice and loward the retraction speed to 15mm/sec.
So I printed twin towers with lower tempatures, and I ended up with 195c having a nice finish and no stringing.
Then I printed my third Ctrl V Print.
On This one, I lowered the default speed to 3000mm/min, and outline underspeed to 45%
Here are the pictures, its starting to look good.
http://imgur.com/a/UVRKH
Edit: Wan't to point out that my Makerfarm has a problem printing on the Z axis. The temperature fluctuates too much, caused the bottom layers to expand and contract, leaving a patern on the Z axis, as if the nozzle was moving up and down. Problem goes away if I turn off the heat bed. I don't turn it off because my glass is thin, and I don't want to break it removing parts.
Here is an example of the difference I get from leaving the heat bed on, then turning it off.
http://imgur.com/jSqAfm6Last edited by sapient24; 06-24-2015 at 01:02 AM.
