Results 1 to 10 of 23
06-14-2015, 11:47 PM #1
Explanation for different options under settings menu
Does anyone have a rundown of the Utilities settings on a FFCP ? Some I've been able to look up some (hope those are right), but a few I'd like to know their purpose. Any info would be much appreciated.
General Settings:
- Extruder Hold (OFF/ON)
- Check SD Reads (OFF/ON)
- P-Stop Control (OFF/ON)
- Serial I/O (USB/Vart1)
Enable Steppers/Disable Steppers
Thank you for any knowledge able to give.
06-15-2015, 06:20 AM #2
- Sep 2014
- 54
Extruder Hold - it keeps the extruder motor from being disabled by command "M103" and is of use for 3MM extruders - source - http://www.makerbot.com/sailfish/releases
Check SD Reads - sounds like it does an error check against what was received - http://jettyfirmware.yolasite.com/v73-v43.php#crc
P-Stop - looks to be so you can add an external trigger to stop the printer via hardware - http://jettyfirmware.yolasite.com/v74-v44.php#pstop
06-15-2015, 08:40 AM #3
"steppers on/off - does exactly what it says.
If you have the motors on - the carriage will be rigid and you won't be able to move it around by hand. Plus the motors tend to get a bit warm :-)
With it off, the motors are only on when printing or 'jogging'. So the carriage moves freely and the motors don't get hot."
Thank you both for taking a little time to drop some knowledge on a fresh rookie.
06-15-2015, 06:46 AM #4
06-15-2015, 09:02 AM #5
- Sep 2014
- 54
No problem Roob, TBH I haven't found a need to change any of the settings I commented on so far - though I do only tend to print right from USB personally and have no need of the other 2 settings that I have found.
06-15-2015, 10:46 AM #6
06-17-2015, 10:49 PM #7
- May 2014
- 35
Is there any manual that says what all the settings are? I just got a Creator Pro, my first printer, and am leery about pushing buttons as it doesn't seem to have intuitive behavior.
I ran bed leveling and upon completion ("ok"), much to my surprise, the bed sat there, right under the extruders. Then I prepared for the test print, the calibration box. I loaded the filament and as I prepared the sample calibration box gcode and moved the x3g file to the SD card, the filament oozed out and pooled up and around the extruder.
Also, no documentation under ReplicatorG's Help/Offline Documentation. Would anyone know where this file should be? The error message on the console says "Could not load offline documentation."
06-18-2015, 01:05 AM #8
06-18-2015, 09:01 AM #9
- May 2014
- 35
First print trouble
I leveled the bed via the LCD. If you load the filament first, isn't that going to make one heck of a mess oozing plastic with a paper sliding around underneath it? And possibly set the paper on fire?
Now there's a pool of plastic stuck to the extruder. I take it I'm going to have to lower the bed manually and turn on the extruder's heat to get this off. And I'll be guessing my way through it with the LCD. I'd be fine with that if there were no way to damage the machine but the original instructions that came with it, a simple walkthrough, says yes you can damage the machine.
So, how much time do you have between load filament and test print? Following the original instructions, it said load the filament/turn on the extruder heat, then prep your object for printing. Not really, if the filament's oozed out and globbed onto the print bed.
06-18-2015, 04:07 PM #10
Ok there are two ways you can move your bed without having to touch it. 1.) LCD Menu on actual printer --> "Utilities" --> Then scroll down until you see then select "Jog Mode" --> hit Right direction arrow twice, your screen should read as follows:
Jog mode
Z-
<-Y (Back)
Z+
At this screen you should be able to lower and raise your bed using the up and down direction buttons on printer.
2.) The alternative way includes Replicator G if you choose to use it: The top tool bar in RepG there should be the "Control Panel" button it has 4 arrows pointing in the basic directions (up, down, left, and right). This well take you to the control panel. Under "Jog Mode" make sure the drop box is set on "continuous jog" and then use the Blue Up and Down arrows that control the Z axis to move your bed. I apologize for not posting pics, for whatever reason it wouldn't upload any I tried. I'll work on your next question and get back to you.
