Results 1 to 10 of 66
Thread: Mount and Reservoir Discussion
06-03-2015, 05:03 AM #8
- May 2015
- 43
I'm not sure this is the case, bigger build area, bigger build therefore more resin to cure, as with all lasers the power is limited this means the laser will take longer to cure each layer. Which means it needs to be kept slow.
If the current limiting factors on build speed are related to the moving the mirrors (slow and steady to avoid vibrations etc) then you can up the Z-axis speed. If the laser is the limiter then the z-axis will need to be kept just as slow.
I could be totally wrong though…
