Results 11 to 20 of 29
06-02-2015, 10:25 AM #11
- Mar 2015
- San Diego, CA
- 107
06-02-2015, 10:38 AM #12
I ran the same file in Black and Red and got similar results. I think my settings are at 60mm/s also, however due to accceleration curves and the small part size I doubt it gets to that speed. Outlines are set to 50% speed also.
Attachment 6207Attachment 6208Last edited by jfkansas; 06-02-2015 at 10:54 AM.
06-02-2015, 10:39 AM #13
06-02-2015, 01:28 PM #14
- Mar 2015
- San Diego, CA
- 107
06-02-2015, 02:14 PM #15
The tolerance between the filament drive gear and plastic is much tighter. The filament is fully supported after the drive gear.
The stock plastic is 4 pieces, and 3 screws. This design is 2 plastic pieces and 1 screw. I also beefed up the preload on the spring to have more pressure on the flex filament.
There isn't any PTFE in the feed mechanism.
06-02-2015, 02:39 PM #16
- Mar 2015
- San Diego, CA
- 107
06-04-2015, 01:44 PM #17
- Mar 2015
- San Diego, CA
- 107
What do you think about including a wire brush to continuously scrub the drive gear?
http://www.ebay.com/itm/3-pcs-made-i...-/301647740867
06-04-2015, 03:24 PM #18
It really isn't needed, I don't clean my drive gear but about a couple times a month at most. I usually run a #11 xacto knife down the grooves, not a brush. Sometimes a quick blast of canned air is all that is needed. It would also take another perpendicular drive system since you would want to brush along the grooves and not across.
06-04-2015, 04:55 PM #19
- Mar 2015
- San Diego, CA
- 107
Yeah, ideally it would be along the grooves, but with a continuous action, across could be effective enough.
Might be better than taking it apart a couple of times a month.
Then again, if the brush were round and mounted at an angle and allowed to rotate, it could have significant across the grooves motion propelled by the gear motion.
06-04-2015, 06:43 PM #20
You gotta check out my extruder mount. I can have a stepper out gear cleaned and back ready to roll in a few minutes. If I really tried I bet I could do it in under 3min. lol
