Results 21 to 27 of 27
07-28-2015, 05:44 PM #21
- Jul 2015
Hi just got mine together today. I lit up and I went to move the extruder and the screen went all white.
What did I do and how to fix?
Can't find the troubleshooting section in HK "Files"
07-28-2015, 11:03 PM #22
- May 2015
- 39
With the power off, connect the Mega 2650 to your computer USB. If it loads, it could be the 5V regulator on the Mega 2650.
08-03-2015, 04:53 PM #23
- May 2015
- 18
Update on my Parameters:
Without changing my mechanical configuration, i am now able to print with 50mm/s solid, after i dialed down the Acceleration-Seting in the Printer to 500.
The starting-value was 3000.
500 is the lowest possible value and i am currently testing, how high i can set this.
But even with 500, it prints very fast with no loss of reliability.
If someone else got decent values, please post them.
I will make an update, if i have a final value.
08-03-2015, 05:09 PM #24
- May 2015
- 39
I've read to keep acceleration high to keep corners sharp. How are your looking?
08-08-2015, 10:16 PM #25
- Aug 2015
For abs i use
layer height 0.1
shell 0.8
bottom top 0.6
fill 20
speed 50
extruder temp 220
bed 110
1.75
i have to use stick glue
so far so good up to when i flashed new firmware now my heat bed is taking 25 min to heat up.
im going to try the firmware joop posted
08-23-2015, 04:51 AM #26
- Jun 2015
- 7
Fabrikator is back
Hello, i am back with Turnigy Fabrikator, received a brand new one in exchange. I set up it as the first and it is working fine, i did my first prints. Here are the first objects. FullSizeRender (1).jpg
Sometimes when i print an object i got from Thingiverse i have a problem of vertical alignment. For instance this one did not print correctly : FullSizeRender.jpg
I used the default STL file given on website, used Slic3r to convert in gcode, using default value with the correct one for our printer. Do you have any idea ? did someone already face this problem ?
By the way the printer is working quite well for now, i print PLA first using the updated firmware from HK. Will give a try to the firmware update from Joop1987. I tried Cura 14.12.1 and Slic3r 1.2.9
08-23-2015, 05:31 AM #27
- Jun 2015
- 7
i played with Slic3r config and it seems i found a better configuration. Here is the result of the last printed object from Thnigiverse with this config. FullSizeRender (2).jpg FullSizeRender (3).jpg
As you can seen compared to the previous one it is far better !! FullSizeRender (4).jpg
Let me know if you want the ini config file of Slic3r v1.2.9
