Results 1 to 10 of 27
05-22-2015, 03:14 PM #10
- May 2015
- 18
I have connected them the way you described it.
I even disconnected the cables and connected them to another 12V supply to see, if the labels were correct and if there might be a shortcut anywhere.
The mechanical connection is right.
I even flashed the firmware you uploaded to the printer, but still the same issue.
UPDATE:
I completely disassembled the Control board to get to the Arduino Mega.
Digital Pins 8 and 9 seem to be shorted.
I tried with a custom sketch:
Both Pins Low: 0V
Both High: 5V
One Low, the other High: 2.5V
The measured resistance between D8 and D9 with the Arduino off is < 1Ohm.
I thing my Board is broken.... replacement is on it`s way...Last edited by PhilippG; 05-23-2015 at 04:57 AM.
