Results 1 to 10 of 13
05-06-2015, 08:37 AM #1
Rendering issue with latest openscad
So I decided to design a 3d picture pinboard. More as an exercise in openscad scripting and captive printing than anything else.
One of these things - saw one in a cleints house and thought it would be fun to make a one print version.
http://ecx.images-amazon.com/images/I/51R%2BlG4DlAL.jpg
That part worked really well. It's parametric and I can - theoretically - generate any size grid.
Theoretically.
I've generated and printed a 2x2 grid - 4 pins. And it looks like I got my calculations and spacing right first time. Which is bloody unusual :-)
Ideally I want one almost as large as my print bed. And that's where I'm hitting problems.
A 10x10 grid (which would be about 8cm square - I'd like one at least 10x20cm), after about an hour rendering - crashes openscad with a couple of microsoft visual c++ error popups and then openscad just shuts down.
Currently trying a 5x5 grid. Nope bombed out.
The thing is it's a pretty simple script. pin module, hole module and four loops to place first the holes and then the pins in a cube sized according to the number of columns and rows.
There's no shape more complicated than a dual diameter cylinder.
So why does it take so long to render ?
And why does it crash.
And has anyone else had any crash issues with the latest openscad ?
05-06-2015, 10:06 AM #2
Would you mind posting the .SCAD file so we can take a look? But... Even if you can't do that I have a couple of thoughts. Can you turn the matrix of cylinders into square pegs? The reason is spheres and cylinders have way way more triangles to 'compose' them than flat surfaces. Almost for sure that will make it render faster and use much less memory.
I have switched to the 2015-03 version of OpenScad. It is better than the previous version. But I have managed to get those same pop up windows. And once you get OpenScad sick, I think it is best to shut it down and re-open it. It appears to work if you don't do that. But it seems like once it gets sick, it never recovers. There is a very active OpenScad forum. I suspect if you post the code that blows it up a fix will happen!
05-07-2015, 11:33 AM #3
Yeah this is the new version that's crashing. Never had any issues with the earlier versions.
I guess square pins and holes would work as well as round ones. Can't hurt to try. You could be onto something there. I never had any problems with the large crossbow dart holders.
cheers I'll give that a go. The top of the pins are spheres - guess I could knock the facets down to 50 or maybe less.
And when it crashes it shuts itself down, so that's not a problem. f5 works fine, there's nothing wrong with the script.
Yeah, not big on sharing code for cool things :-)
plus it's real simple code.
I don't mind of it take a whole day to render, I've got enough computers to leave one doing nothing else - just wish it would actually render.
05-07-2015, 01:13 PM #4
well dropped the cylinders down to 12 facets, and the speheres to 20 and it finally rendered a 5x5 grid.
The pins and spheres are pretty small so it probably won't look that much different.
I'll knock them down to 10 and 15 and see if it'll do the bigger matrix.
Seems a pretty poor limitation though.
05-07-2015, 05:01 PM #5
Yeah... Well... It is a huge amount of computation to go look for intersections and stuff. I feel sorry for my computer every time I tell it to render something big and tedious like that. If you wanted to get clever, you could make the tops of the pins a polygon. That would be fairly fast to instantiate on each pin and the computation would not be that bad. And for that matter... If you made the pins polygons, I bet your problems go away. The big problem is defining those polygons is a real pain in the @$$.
05-08-2015, 06:50 AM #6
weeelllll, one problem went away - with reduced facets it will render larger grids. But says the resultant model is not a 2 level manifold.
ie: has holes and probably won't print properly. At least I think that's what it means.
Far as I can see nothing has changed in the model layout - no reason why it should.
So why on earth should fewer facets stop it being manifold ?
It gets weird. with 75 facets set globally 2x2 grid renders without any error messages. with 50 facets I get the error message. With 55 - I don't.
Currently workijg my way up to find the facet threshhold that starts generating the error messages.
Then I'll apply it to the individual cylinders and sphere and try to isolate the part that's causing the problem.
weird.
It gets weirder.
If I set global facets to 10 and the sphere facets to 50 - it renders without error. yet with global facets at 50 you get an error.
well - it'll now render a 5x5 with 25 facet speheres (which'll print smooth, my machine's not that precise).
top view
Attachment 5977
bottom view
Attachment 5978
Right I'll try for some larger matrixes and see what happens :-)
Okay I now get the:WARNING: Object may not be a valid 2-manifold and may need repair! See http://en.wikibooks.org/wiki/OpenSCA...ort_and_Export WARNING: Exported object may not be a valid 2-manifold and may need re
Don't get it on render though.
This is just weird. I'm going to have to try and print it to see if there are any actual issues.Last edited by curious aardvark; 05-08-2015 at 07:53 AM.
05-08-2015, 11:01 AM #7
Usually when you get non-manifold stuff in OpenScad it is because you are taking the difference of two things where the edges are at the same location.
This is problematic:
Code:difference() { cube([50,50,50]); cube([25,25,50]); }
Code:difference() { cube([50,50,50]); translate([-.001,-.001,-.001]) cube([25,25,55]); }
05-11-2015, 05:23 AM #8
ah - yes I usually do the second thing. haven't bothered for this script, so that probably make sense.
And I rendered, exported (both with error message) and printed a 5x5 without any issues - so basically I think I can just ignore the message.
It is actually creating a printable and manifold model.
Cheers for the help Roxy, appreciated :-)
Going to try for a 30x20 grid. 600 pins and around 15x10cm
no idea how long it'll take to render - even at the low facet numbers.
that's the main thing that's missing from this version of openscad - it used to tell you how long a render had taken. It doesn't any more. I used to find that really useful.Last edited by curious aardvark; 05-11-2015 at 07:22 AM.
05-11-2015, 02:36 PM #9
You know... I just had a thought... Do you have to render the entire thing? If you were to render a 1" x 1" section of it and place copies of that next to itself on the build plate, you could go to any size that made sense. Or if you wanted to keep it all in source form, with the new OpenScad you could render the 'child()' object and then use that in a multiple for() loops to make it as big as you wanted. The way OpenScad handles children is it only calculates and renders it once, and then it gets used again and again by the parent. It would probably dramatically cut down on the processing time. Maybe you could go crazy and use a very high $fn number and not bog things down.
You would just have to make sure the pattern replicated faithfully in all directions.
05-13-2015, 05:47 AM #10you could render the 'child()' object and then use that in a multiple for() loops to make it as big as you wanted.
And yeah i did think about arranging a bunch of 5x5's on the printbed - but it's a bit tricky getting them all exactly the right distance away from each other. Auto arrange doesn't seem to come with a user definable distance.
And it still crashes with a big grid :-(Last edited by curious aardvark; 05-13-2015 at 05:53 AM.
