Results 11 to 20 of 21
Thread: Solenoid for Z probing
04-26-2015, 03:19 PM #11
- 114
Okay, thanks I got it here, but haven't put the circuit together, since it cannot find a 12v out to use. Okay, if I would have read the whole story I would have seen this.
Aux 2 63 and GND right next to it. Will try that.
Thanks for your help!Last edited by Fri; 04-26-2015 at 03:34 PM.
04-26-2015, 03:40 PM #12
Actually.... You don't need a '12 volt out'. That circuit has a MOS-FET that switches the power. You just need a 12 volt power supply. That MOS-FET is handling all the power switching for you. In that article there is this picture: http://i.imgur.com/Bbs3Mmg.png
It says at the top of the picture 5 volts. But you can connect the drain of that MOS-FET to 12 volts without any worries. Or more accurately, VDD at the top of the diagram can be 12 volts instead of 5 volts. That MOS-FET is being turned all the way on and all the way off. It doesn't really care how much voltage it is switching. You can just grab 12 volts from your power supply and feed it into that circuit instead of 5 volts.
04-26-2015, 04:19 PM #13
- 114
Okay, now I think I got it.
Thanks so much
05-26-2015, 09:19 AM #14
- 114
I got it all working great. One thing I got I don't know why is the M114 is not working. I am using a Ramps with a current Marlin, but the m114 command doesn't do anything. Any suggestions?
05-26-2015, 09:39 AM #15
M114 Should always be there. The fact it isn't responding is not good! I think I would search Marlin_main.cpp and verify that the code is present. It should look like:
Code:axis_steps_per_unit[i] = code_value(); } } } } /** * M114: Output current position to serial port */ inline void gcode_M114() { SERIAL_PROTOCOLPGM("X:"); SERIAL_PROTOCOL(current_position[X_AXIS]); SERIAL_PROTOCOLPGM(" Y:"); SERIAL_PROTOCOL(current_position[Y_AXIS]); SERIAL_PROTOCOLPGM(" Z:"); SERIAL_PROTOCOL(current_position[Z_AXIS]); SERIAL_PROTOCOLPGM(" E:"); SERIAL_PROTOCOL(current_position[E_AXIS]); SERIAL_PROTOCOLPGM(MSG_COUNT_X); SERIAL_PROTOCOL(float(st_get_position(X_AXIS))/axis_steps_per_unit[X_AXIS]); SERIAL_PROTOCOLPGM(" Y:"); SERIAL_PROTOCOL(float(st_get_position(Y_AXIS))/axis_steps_per_unit[Y_AXIS]); SERIAL_PROTOCOLPGM(" Z:"); SERIAL_PROTOCOL(float(st_get_position(Z_AXIS))/axis_steps_per_unit[Z_AXIS]); SERIAL_PROTOCOLLN(""); #ifdef SCARA SERIAL_PROTOCOLPGM("SCARA Theta:");
06-06-2015, 09:58 AM #16
- 114
The code is there, and I am not sure if it is not responding. When I home all, and then do a M114 my z should report a number other than zero, but it is always on zero. M119 and other M codes work fine.
06-06-2015, 03:16 PM #17
The M114 unconditionally prints "X:" and the number. M119 has this code:
Code:case 119: // M119 SERIAL_PROTOCOLLN(MSG_M119_REPORT); #if defined(X_MIN_PIN) && X_MIN_PIN > -1 SERIAL_PROTOCOLPGM(MSG_X_MIN); SERIAL_PROTOCOLLN(((READ(X_MIN_PIN)^X_MIN_ENDSTOP_INVERTING)?MSG_ENDSTOP_HIT:MSG_ENDSTOP_OPEN))
03-17-2016, 01:27 PM #18
- Mar 2016
hey im trying the same thing on my printer, i managed to get it working with the marlin firmware provided in the post but i want to use the newest version of marlin do you guys know which section i need to change in the marlin_main.cpp? because the part that is supposed to be modified is not there
this is what is supposed to be modified:
static void engage_z_probe(int d = 100) { //lower z probe
digitalWrite(Z_PROBE_PIN, HIGH);
delay(d);
03-17-2016, 03:21 PM #19
03-17-2016, 04:43 PM #20
