Thread: Inverted Z-axis
04-21-2015, 02:45 AM #1
Inverted Z-axis
Hello everyone!
Gathering Chinese Prusa i3 and disappointed fragility design and print quality, gathered his. Of the details taken from the Chinese.
But now I axis Z - upside down. Settings in the software "inverted axis Z" does not help.
Need to get into the firmware? Who knows how to "cure"?
my printer:
05-18-2015, 07:30 AM #2
I understood - in the firmware have options that set the direction of motion along the axis:
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
true or false determine the direction
05-19-2015, 04:57 PM #3
Yes... You can flip the direction of axis movement by changing those #define's. But make changes carefully. Check them out with PronterFace and be ready to press the Reset button! The problem is you also have to have your limit switches #define'd correctly. So, if you get things to move rationally with PronterFace, you can use the M114 command to verify the limit switches are detecting the end of travel on a given axis.
That is a very nice looking printer! I wish my printer was made like that.
05-20-2015, 04:01 AM #4
Thanks for the help!
If I move the node to the other side, I quickly pressed a hand to the limit switch.
Today, 03:08 PM in 3D Printer Parts, Filament & Materials
