Thread: Solidoodle 3 printer HELP!
04-14-2015, 12:53 PM #1
- Apr 2015
I purchased a Solidoodle 3 printer a while back, used it a bit then put it aside for about a year. When I got it back out I could move X Y Z and extrude manually (from the manual control panel). However, when I sliced an STL file and printed it, the extruder head would move X and Y and the table would move in Z, but it was not extruding any plastic. I could see extrusion commands in the G-code, but nothing was coming out.
I contacted Soldioodle support and they responded pretty quickly with what I think are standard responses - check this, check that, etc. I installed the serial driver, got an error message that it may not have installed properly so had it do it over. Still no printing extrusion.
I re-installed Repetier Host - and now I had a duplicate list of printers. Selecting the correct one, I was still able to move everything and extrude manually, but no extrusion while printing.
I uninstalled and re-installed everything (still have the duplicate list of printers) and now it will not even move. Tried it on a different computer, no movement.
I then noticed that on the Manual Control Panel there were messages like "4 commands waiting", and if I tried to move something from the Manual Control Panel the number of commands would increase.
These are the commands on the log:
16:44:07.055 : OpenGL renderer:NVS 3100M/PCIe/SSE2
16:44:07.055 : Using fast VBOs for rendering is possible
16:44:17.085 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
16:44:17.090 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
16:44:17.091 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
16:44:17.099 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
Obviously there is an IO problem but I have no clue on how to solve it.
I used Windows 7 device manager and removed the USB serial interface and re-installed it (by connecting the printer) but still no movement.
I can hear a "clunk" kind of sound whenever I connect the USB cable, and the red light on the printer mother board will light (and is steady) when the USB is connected with or without the main power being connected.
Anyone have any suggestions?
Thanks
Jeff
05-07-2015, 05:37 PM #2
It sounds like a jammed nozzle. This typically happens when the printer gets used, then idles with the filament. What you need to do is melt the remaining filament from the nozzle. If you can do this manually, it would be good as I don't think the Solidoodle machine may not suffice to preheat the remaining filament. If you can also manually remove -- pick out the filament by longnose pliers -- that would also be good.
Do you see the extruder spinning the gears freely but nothing is getting melted? If so, then it's definitely jammed nozzle. The "clunk" sound you hear is from the extruder gears pushing its best into the hot nozzle but can't since it's more than likely jammed. This has happened to us quite a few times when we've left our printers idling even for a couple of days with the filament on. We've learned that it's best to immediately remove the filament once the print job is complete.
05-07-2015, 06:01 PM #3
- Apr 2015
I have cleared the nozzle, it will manually extrude, just not during the print. Have not paid attention to the gears - good idea to check that!
