Results 1 to 8 of 8
Thread: Z Resonance Issue
03-14-2015, 01:22 AM #1
- Dec 2014
- 14
Z Resonance Issue
Hi, I am relatively new to 3d printing, but I have worked out that I have a Z Resonance issue.
Here is a picture of the issue
http://i.imgur.com/ssVE0eG.jpg
I have seen a few people say that removing the bearing on the top of the z axis threaded rod fixes the issue. This is great, however I am not sure how to remove it without damaging the printer beyond my fixing.
I would like to try to fix this myself before contacting flashforge directly.
Any help that this forum may provide would be greatly appreciated!
03-14-2015, 05:21 AM #2
- Oct 2014
- 93
i dont have a baring or stablising point on my 3d printer, yet i still suffer from this, i though about adding one to compensate
03-14-2015, 07:56 PM #3
All flashforge printers, at least pros and creator x have a bearing at the top of the z rod. It is pretty easy to remove, easiest way is to remove the back, that gives you full access to the 4 bolts that hold the z stepper in the bottom. Remove these and the platform and z screw will drop out of the top support. Then you can dig the bearing out with a small screwdriver. Bolt things back up and put the back on and should be good to go.
03-14-2015, 08:03 PM #4
- Dec 2014
- 14
03-14-2015, 08:14 PM #5
haha, ya, it is easier to get to the bolts with the back off. That wobble is very common if the z rod is fully captured. It also depends on how badly it is bent. If mine was bent that much I would try to replace it or have a new one sent if it is under warranty.
03-14-2015, 08:29 PM #6
- Dec 2014
- 14
03-14-2015, 10:53 PM #7
- Apr 2014
- BC, Canada
- 29
Your pic looks like it may have a problem with a loose X belt! (it should be quite snug- almost pluck it like a guitar string)
A Z axis wobble shouldn't affect a print like that, as the Z axis is on two (quite firm) linear bearings/shafts
My FFCx never had a bearing at the top of the Z rod, just a plastic mount - with lots of clearance.
It did tend to wobble, dropped the Z stepper & machined a nylon bushing for the top..probably not necessary, but did it anyway..never affected anything.
03-14-2015, 11:09 PM #8
- Dec 2014
- 14
05-17-2024, 12:15 PM in 3D Printer Parts, Filament & Materials
