Results 1 to 9 of 9
Thread: Molecular Manufacturing is Here
03-13-2015, 04:52 AM #1
Researchers at the University of Illinois have created what may end up being the future of 3D printing. In a device they call a 'molecule-making machine' they are able to synthesize literally billions of compounds from hundreds of small molecules. Currently the technology is in the process of being improved after a major investment from a company called Revolution Medicines. Burke, the lead researcher and chemist says that compounds can already be created with the device which humans have never made. The machine, dubbed a 3D printer, of chemistry could prove invaluable in the discovery of new drugs as well as new chemical based technologies. More details on how this incredible machine works can be found here: http://3dprint.com/50777/molecular-3d-printer/
Below is a picture of this new 3D printer:
03-13-2015, 12:50 PM #2
That looks both imposing & menacing, in a good way I suppose.
03-14-2015, 08:35 AM #3
This looks like a mad scientist's machine. I'm guessing it's a bunch of syringe-like extruders connected by plastic tubing to a print head - actually, judging from the tubing into the flask, they may be individual heads. More like a paint color mixing machine. Undoubtedly a big leap forward for chemistry - it will be exciting to see what develops.
10-04-2015, 09:03 PM #4
- Oct 2015
Dr Sinclair has discovered a way to reverse aging with a chemical called NMN (nicotinamide mononucleotide) it cost like 300,000 for small amounts Can this machine make it much cheaper? How much could it print in day and costs for that?
09-05-2017, 09:24 AM #5
- 26
Since I'm investigating molecular manufacturing
(or atomically precise manufacturing APM - the newer name)
I think I can clarify a bit how this development brought up here ties in into the big picture of APM.
First some minimal details about what this "molecule making machine" here is actually all about:
http://www.scs.illinois.edu/burke/fi...32_Science.pdf
The the "Suzuki coupling" is used to make carbon carbon bonds
https://en.wikipedia.org/wiki/Suzuki_reaction
like so: ...≡C-B(OH)2 + Br-C≡... - > ...≡C-C≡... + waste
To continue after a first reaction one needs pre-delivered
building block molecules that are at least double capped
like so: Br-C≡...≡C-B(OH)2
But this would self polymerize. That is it would form "infinite" chains.
So the solution found was to temporally cap (chelate) the boron end with a molecule called-
"trivalent N-methyliminodiacetic acid (MIDA fro short)" like so:
http://www.sigmaaldrich.com/chemistr...boronates.html
For purification it was found that the MIDA caps on the growing product molecules can be locked/released to/from silica particles by different solvents.
Limitations of this process that I'm not clear about are:
# How small/big can the pre-delivered building block molecules be?
# The pdf-document says that they can create loops. How? How tight can these loops be? How close can they be together? (I highly doubt big polycyclic diamondoid cages are possible. Not to speak of strained ones.)
# Can this be done hierarchically or only serially? (Hierarchically would extend scalability a bit.)
Limitations that are obviously present:
Since this is conventional chemistry and not mechanosynthesis the yields are low and the error rates are high. Every synthesis step can easily have losses in the single digit percentual range. Thus this is only suitable for small molecules (as the work says itself) and does not scale up very far.
In light of early APM I suspect this could be useful for:
# The synthesis of light activated "motor molecules"
# The synthesis of novel side chains for foldamers (for boosting stiffness & symmetry)
# Maybe short self-assembling strands (like in structural DNA nanotechnology that exclusively uses short oligonucleotide strands)
With early APM I'm referring to "Coarse-block APM systems" page 33:
https://energy.gov/sites/prod/files/...%20Drexler.pdf
I'm not referring to what is shown in the INFAPM workshop video! That video is (as I see it) just about the "System-level tech demos" dead end in the diagram.
While the "molecule making machine" here certainly is a major step for medicine I'm not sure about in how far this will tie in into the bootstrapping of advanced APM.
I'm writing a website about APM atomically precise manufacturing:
http://apm.bplaced.net
As a side-note: I certainly wouldn't count that molecule making process as a form of "3D printing" just because it's additive manufacturing.
# It handles discrete parts. That is usually called pick and place assembly but ...
# There is also no active positioning involved whatsoever.
It's more like going from painstaking chemistry-research to straightforward chemistry-engineering. But the term "chemical engineering" is already taken.
"Programmable chemistry" maybe ... ?Last edited by mechadense; 06-07-2018 at 02:28 PM.
05-15-2019, 01:07 AM #6
- May 2019
- New York
Biomaterials
Biomaterials are a class of high-tech materials used to diagnose, repair, or enhance their function in human tissues and organs, that is, natural or man-made materials used to replace and repair living tissues, and their effects are irreplaceable. Biomaterials can perform, enhance, or replace a function that is lost due to illness, injury, and so on, but can not restore a defective site.
05-15-2019, 01:13 AM #7
- May 2019
- New York
Bioelectronics is a new academic discipline formed by the cross-infiltration of biology and electronic information science. In November 1991, at the first CEC seminar in Brussels, bioelectronics was defined as the use of biological materials and biological architectures for information processing systems and new devices.
05-15-2019, 01:17 AM #8
- May 2019
- New York
Carbon nanotubes, also known as the Pakistani tube, are a one-dimensional quantum material with a special structure (radial dimensions are in the order of nanometer, the axial dimension is in the order of microns, and both ends of the tube are substantially sealed). Carbon nanotubes are mainly composed of hexagonal carbon atoms, which constitute several layers to dozens of layers of coaxial tube.
05-15-2019, 01:20 AM #9
- May 2019
- New York
3D printing has revolutionized the manufacturing process and is transforming the world, which transform the design ideas quickly into real, especially ones with complex structure which is complicate to produce. At this stage, there are two factors to limit the development of 3D printing technology——printing materials and equipment. Currently the main 3D printing material include engineering plastics, photosensitive resin, rubber materials, photosensitive materials, ceramic materials and metallic material and in the form of powder, filamentous, lamellar and liquid-like.
