01-10-2014, 08:16 AM #1
mbot3D GRID II Announced - €1,245
mbot3D just announced their new 3D Printer. It seems like it is only available in Europe for now though.
The GRID II is a third generation printer from mbot3D. This sturdy metal frame 3d printer has one of the biggest build sizes on the market for desktop 3D Printers, 260x230x200mm. It is available in single head or dual head configuration.
The new printer features an automatic build plate calibration system that guides the user through the setup and then at every print probes the surface and uses the calibrated distance. The printer also features a glass build plate , and a magnetic build plate holder making it a breeze to remove your build plate to remove your prints, which ensures your build plate calibration is kept in top condition.
The mbot3D GRID II also feature single or dual print fans to make sure your PLA prints are perfect every time!
The printer is bundled with a SD card, and an exclusive tool box with the basic tools need for maintenance of the printer.
SPECIFICATIONS
PHYSICAL DIMENSIONS
Size 405 mm x 405 mm x 410 mm
Shipping Box 520 mm x 520 mm x 520 mm
Weight 18 Kg
ELECTRICAL
AC Input 100-240V, 50-60 Hz
Power Requirements 24V DC @ 6.25 amps
Connectivity USB, SD card with SDHC support
MECHANICAL
Chassis Steel
Front Cover PVC Panel
XYZ Bearings IKO Linear Bearings
Stepper Motors 1.8° step angle with 1/16 micro stepping
SOFTWARE
Firmware Sailfish OS Firmware
Printer Host Software ReplicatorG
File Types STL
Operating Systems Windows(XP/7/8/8.1), Ubuntu Linux(10.04+), Mac OS X (10.6+)
