Thread: FlashPrint Model Disappears
03-06-2015, 09:59 AM #1
- Feb 2015
- 13
I am using FlashPrint with the Dreamer and the default slic3r. Sometimes I am trying to set it up to print and I get a slicing progress bar that looks like it is doing something. But when it gets to 100%, the model disappears. I get a window with an estimated build time of 0 minutes and buttons for "print" and "back". If I click on "print", nothing happens. If I click on "back" the model reappears and it looks normal. I have had some success by turning off the Dreamer, exiting FlashPrint, and starting over with loading STL files.
Does anyone know what is going on?
03-06-2015, 10:50 AM #2
- Dec 2014
- North Carolina
- 23
I suspect the stl file has defects. Try checking it with netfabb. I have seen this behavior when trying to create very thin or short structures. Also try the other slicers although the ffslicer and skeinforge seem to generally have more problems.
Graham
03-06-2015, 11:56 AM #3
- Feb 2015
- 13
I was very frustrated today with a certain print. I had reduced a thickness to 0.1 inch or 2.54 mm. I tried it about 10 times and it finally worked. I don't know what was different, but the STL files were the same. I tried skeinforge and got a "something went wrong error".
I will try the netfabb check.
03-06-2015, 04:30 PM #4
- Feb 2015
- 13
Netfabb says the STL files are good.
Now that I think about it, the model does have some thin features where one color blends into the other.
