02-15-2015, 02:58 AM #1
- Jan 2015
- 306
Supports sticking VERY firmly to part
When I print with supports, they get very stuck to the main piece and make it nearly impossible to remove. Most of the time I have to go in with a dremel and cut it out, and that scars my piece. What should I do to resolve this?
02-15-2015, 05:25 AM #2
print without supports ?
So, what printer, what software, what model.
You can't get answers without giving details :-)
02-15-2015, 03:54 PM #3
- Jan 2015
- 306
Type A machines Series 1
KISSlicer
PLA at around 190, I tuned the steps/mm of the extruder and this temp seems to be the best for this PLA. Not sure what else to do to keep the supports from bonding so hard. Printing without supports is not an option, the part will fall apart.
02-27-2015, 03:27 PM #4
- Feb 2015
- 10
I'm bumping this because I'm having the same issue.
Printer: DiamondAge Moa
Software: Slic3r
Model: Michelangelos David, from user 3DWP, Thingiverse.
02-28-2015, 03:18 AM #5
It was very difficult for a printer and most of the printer are telling that it is impossible to take a print without sticking, you just take the help of printers who are expert in removing the sticking very easily. You must use a 3-d printer, which are having a spatula and scraped knuckles which remove the print very easily.
03-01-2015, 04:18 PM #6
- Oakland, CA
- 935
Use a dual-extruder printer which can produce soluble supports. For instance, ABS prints with PVA supports.
Andrew Werby
www.computersculpture.com
