Results 1 to 5 of 5
02-23-2015, 01:29 PM #1
[ EX2 / M180 ] Extruder problem and general help
Hello all !!
I'm brand new on this forum as I couldn't find any french one popular enough to hope finding help on it.
I own a Freesculpt EX2 printer which is the same as the Malyan M180.
I try to make it work properly but i have one issue with my extruders, I tried to explain it but a video speaks better than anything !
In a nutshell, and for SEO reasons, it seems my filament is not getting well through the extruder, it makes dotted lines and when I try to print an object it makes some imperfection on it.
More generally, I have issues with quality and speed and can't find a good parameter. In my opinion, if this first problem can be solved, I'll be almost good to print nice things !!!!
Thanks !
02-23-2015, 03:03 PM #2
- Jan 2014
- 462
Your extruder is definitely skipping steps. You might be printing at too low a temperature, or too quickly. Temperature and speed are the two parameters I'd play with initially.
02-23-2015, 03:48 PM #3
Well thanks for your answer!
Here are the settings I'm using :
ABS : 230 C⋅
Bed : 110 C⋅
Feed rate : 30mm/s (or 20)
Speedrate : 60mm/s (or 40)
Line height : between 20 and 30
Extruder : 0.50mm (even if the manufacturer says it's 0.35 everybody agrees over the Web that for this model it's 0.50).
And for PLA the same but 185c⋅ and bed at 60c⋅
And I have the same results with ABS and PLA which made me think it's the printer (it's also the same with the second extruder).
I thought of something : can it be the filament roll stand? I tried to tight it more and to tight it less but no change. I'm really lost with that.
02-23-2015, 05:01 PM #4
- Jan 2014
- 462
Try a print with the nozzle size set at 0.35 mm. If it is, but you're set up for 0.5, you're going to have problems.
02-24-2015, 02:42 AM #5
Hello !
I tried with 0.35 (one made with ReplicatorG, another one with KissSlicer), and it printed barely nothing !
There is one guy in France that seems to be an expert of that printer, he told me maybe I should change my extruder (that one is Chinese crap :/).
I'll let you know !
Ender 3 Neo - Jam Problem
