Results 11 to 20 of 27
02-19-2015, 06:39 AM #11
- Burnley, UK
- 1,662
Roll a 50mm wide length of aluminium foil round one end then slide it over the one to be joined, make sure they are firmly touching and heat it. Apply a bit of pressure to make sure they are together but not enough to make the foil spread. That is how I join filament and as long as it melts then it should stick together.
02-19-2015, 06:57 AM #12
02-19-2015, 07:02 AM #13
02-19-2015, 07:22 AM #14
- Burnley, UK
- 1,662
I use one of those lighters that has a proper flame, small blowtorch type thing for pipes or a small blowtorch. A gas cooker will do it just fine provided you don't set your fingers on fire, well it will probably work even if you do set your fingers on fire but you may regret it.
02-19-2015, 07:59 AM #15
03-28-2016, 06:37 AM #16
- Feb 2016
- 6
Hi, i m on the same wagon.I read about the epoxy smooth on has for top coating the prints.it works on ninjaflex try it to glue the parts maybe it works if you apply the epoxy on both surfaces and then attach them to each other before it hardens it has 10 minutes working time, amount and an other solution is to use a 3d printing pen to extrude ninjaflex
03-28-2016, 06:49 AM #17
- Burnley, UK
- 1,662
03-28-2016, 07:29 AM #18
- Feb 2016
- 6
03-28-2016, 11:15 AM #19
- Burnley, UK
- 1,662
03-28-2016, 11:24 AM #20
